Anyone tried the Powr-Flo Mass Air Sensor from jet performance?
NOPROBROBB
UTAH
Anyone try one of these, this is what they re claiming off their website: http://www.jetchip.com/JET_Accessories.asp
Powr-Flo Mass Air Sensors:
The JET Powr-Flo Mass Air Sensor delivers improved horsepower, torque and mileage from your car, truck or SUV by simply replacing the restrictive stock mass air sensor. The factory sensor not only is a major restrictive point in stock intake systems, but it also limits the full potential of aftermarket cold air intake systems. The flow bench tested design of the JET Mass Air Sensor provides airflow increases of up to 45% and installs in 10 minutes or less. Compatible with other aftermarket upgrades such as computer upgrades, cold air intakes, TBI spacers, free flow exhaust systems, etc.
*Available for 1994-2008 GM, 1990-2007 Ford and 2005-2007 Toyota vehicles.
Increased horsepower and low end torque
Improved mileage
Simple 10 minute installation
No other vehicle modifications required
Optimizes cold air intakes
NOPROBROBB
NOPROBROBB
UTAH
cool, thanks, thats all i needed to hear, Im looking into getting a new muffler and 3 inch piping and just found that online today so wanted to check before doing anything
BOSS
The People's A D M I N
Dallas
Take the money and spend it on a BB tune for a much more satisifying result. Justin can tune your stock MAF and adjust the timing such as to increase the power output of your engine.
BOSS
NOPROBROBB
NOPROBROBB
UTAH
BOSS
Thats a very good call, I just got my Magnaflow installed today, the BB tune is my next in line to get done. Does the BB tune effect my ability to tow/haul, I dont really know how it all works yet.
JennaBear
Resident Ninja
San Diego, CA
The three gents above me already hit it on the head- the aftermarket MAFs are a waste of money, the stock MAF works just fine up until ~600HP.
As far as a tune with the tow/haul, it will optimize the shift points but won't make you loose the towing capability.
Bromaguire
Chagrin Falls, Ohio
So what do you recommend for 600+?
Narco
Atlanta
lol, theres only a small handful of people here that have to worry about hitting that 600+ threshold...bromag is one of em
Volant1
Volant guy
Upland, CA
I run a granitelli MAF and I noticed a difference, I do have a couple of performance upgrades though :) but im still under 600
JennaBear
Resident Ninja
San Diego, CA
The MAF itself will not result in any measurable gains when all other factors remain equal. It is very common that aftermarket mass air readings are significantly lower (errantly) than pre-modifications readings. This lowered airflow reading will "permanently" result in an increase in ignition timing, due to referencing an area of the spark map associated with a lower density air charge. This increase in ignition timing on a factory tuned ECU will almost always result in a mileage and power gain. This gain is a side effect of the MAF and not directly attributable otherwise. At the same time, it is very common for the MAF to immediately yield LESS full throttle power due to a significant lean condition until the computer has had a chance to compensate via long term closed loop fuel trimming. Additionally, a lower airflow measurement will result in a lower torque calculation by the ECU, which will yield a softer shift and quite possibly a shortened transmission life (have seen it happen).
veteran111
