mdnitedrftr
CT
Dropped my XL off at the mechanic today to confirm my suspicion.
Gonna yank the heads, and send them off to the machine shop. While he's in there hes give it a tune up, maybe throw a new water pump on there, etc...
$3k+ :pp:
Fosscore
Did passenger side moog hub assembly since my abs activates every time I come to a complete stop but didn't fix it. So now going to look at driver side abs sensor and see if that's the problem. Also ordered a couple days ago led fog light bulbs since @Fosscore said they were nice and bright.
@Pachanga02
The LED output is pretty good considering the OEM housings, but much better than the weak halogens.
Nice when you hit somebody with the all lights on though.
Fosscore
Washed her up. Drove to get balloons for my daughter's 8 year old special runway fashion show birthday party.
Then it rained, but she's still sitting pretty in the driveway. Maybe I'll wipe her down after the party.
Pics just because.
quest51210
The amp was benched at 489rms at 4ohm sometime back when I first bought it in 2013ish. It sounds good enough for me. I'm well beyond my days of 154db on 3-8's ported.
The wheel hub bearings showed up today but the upper control arms won't be here til tomorrow. So, that may be a Monday job and then get it aligned.
Hid my amps in the console today.
Need to resurface that monitor pod sometime, it was from previous owner.
Kenwood I installed a fee days ago.
Sub box, 10" Kicker
Inverter connections
You did a nice job on your install. I like the sub install, stealth is good! Is that a DVD player in the console? Or a double din radio?
quest51210
It's just a monitor. I plan on hitting it with filler putty and then probably vinyl wrap it....or if I get bored enough I'll do an iPad or something.
And thank ya, I definitely wanted to hide it as much as possible.
05Single
afraid of the dark
Sub box, 10" Kicker
I like those 2nd row outlets, I've been thinking of what to replace my rear radio with. That thing is so pointless and outdated now lol.
Also you got the dimensions specs on that box? How's it sound?
05Single
afraid of the dark
The box is a copy of a mtx thunderstorm a buddy had...I used his box outer dimensions to build it.
Lol smart. I was thinking of buying the thunderform box and stealing the dimensions and sending it back. I ain't paying $500 for a shallow 10 box. All those boxes are over priced. I bet yours sounds better with wood compared to plastic.
Sub box, 10" Kicker
Wait... what Thunderform did you copy? That doesn't look anything like mine. It would be extremely hard to make the one I bought for the NBS vehicles. It's shaped to take advantage of every bit of available space in the area behind the panel in order to get .8 cu ft. out of it. I wouldn't have paid as much as I did if making one would have been easy. Here's what the real thing looks like and you can't see the complicated rear part of it. It's also pretty thick and has sound deadening material inside to make it sound better. It does sound good, especially with 400 watts RMS into a 10" JL Audio sub.
Yours:
Mine:
quest51210
Like I said, I borrowed some dimensions and I only needed 0.5cuft sounds great and hits great on everything from Stevie Ray to Big Krit
05Single
afraid of the dark
Yea can't make an exact replica with all those curves and that extension. Just enough for dimensions to fit behind the trim.
So how about those dimensions @quest51210 ? Lol
I was gonna take it a step farther with fiberglass. But we will see when I get there, eventually i want a nice 8 or 10 in that spot. Right now I'm happy with my L7 12 rattling my brains.
#1taho
5150TAHO
niagara falls ont
Went to empty out my wife's uncles truck. He had a double head on collision. The first one wasn't so bad. But when the truck was in a spin he got nailed again while the air bags were deflating. He got hit by two small cars. A saturn and a Kia Soul. Good thing it wasn't anything bigger cause the two small cars did a hell of a number to the truck. He broke some ribs and bruised up from the seat belt but walked away
The drivers side got hit first. It wasn't too bad but the second hit did the most damage. Good thing there was no passenger.
wwiizz
