BigDaddy13440
Rome, NY
Big kids! I have the opposite problem. Wife is tiny, my step daughters are very little and can hardly get into my Jeep and its only on 32" tires
Curious about how that bracket was made. Do you have any pictures?
I actually did the same thing for my '00 Wrangler - had a metal shop make brackets to my drawings, pushed the back seat back 4" and up 4". Needed to, as I made brackets to move the driver's seat back about 3". Only problem with the back seat now is my daughter hits her head on the soft top if she sits up straight.... but it's great for summertime ******* drives.
95escahoe
Plugs, wires and spark plug wire shields came today
95escahoe
What did the wire shields cost you and why did you need to replace them? Instead of reusing the old ones.
Got them off Amazon for $4.80 ea they list for $8 and change, mines missing them and has some Autolite wires and plugs so figured I'd switch to OEM
Forgot who posted it, but said the shields we're OK to reuse if they're still red inside. I don't remember what the reason for that was.
TheAutumnWind
Hrm... i dont remember seeing any red inside, though I certainly wasn't looking for it. I reused mine.
osiris94ej
Casper Wyoming
Red inside the plug wire shields? Never have I ever seen red inside them. I have owned 10 or so LS based trucks and have replaced plugs in at the least 30-40 of them. So not sure what that means.
Sent from my SM-N920V using Tapatalk
Red_Raider
Derby, Kansas
Oil change, front and rear brakes with slotted and drilled rotors, and some bilstein action. After inspecting the frame while doing all of this, I see some wire wheel and re painting the frame.
Martinjmpr
Littleton, Co
Bug deflector installed. Yeah, I know they don't look great but after seeing the beating the leading edge of my hood took after a long trip this Summer I think it's necessary. Super easy install.
Photobucket is down so I can't post pics.
Red_Raider
Derby, Kansas
This is my second set I've bought from them. The first set I put on the 02 Tahoe and loved them! I would definitely recommend these for anyone needing new ones.
You could use 3M clear film.
Pachanga02
Ny
Did passenger side moog hub assembly since my abs activates every time I come to a complete stop but didn't fix it. So now going to look at driver side abs sensor and see if that's the problem. Also ordered a couple days ago led fog light bulbs since @Fosscore said they were nice and bright.
Hodmjstone
