05Single's virgin build thread. 03 tahoe
05Single
05Single
afraid of the dark
Going to utilize the bolt holes from the side steps
Man, those are pretty bright. Years ago I saw a white trans am with under glow neons, think it was purple or pink. Coming down a dark road, the car looked like it was floating down the road. Looked pretty cool.
05Single
05Single
afraid of the dark
Well now rock crawler lights are all the rage. These are just as bright (maybe brighter) and can also be mounted anywhere, ...wheel wells, grille, exc...
I like this idea cause you can replace one light if one light goes out where a strip if a light or two go out you have to replace the whole strip. And a strip is limited for muting options.
But these are only one color.
Smoke Em All
Taylor,Texas
Ordered these yesterday.
Took the fogs off for some work. Tried to push the chrome shield away from the bulb to let room for longer hids bulbs later on. Also maybe free up some light.
I didn't like it so after I wet sanded the lens i opened them up using a heat gun and two flat heads and patients and removed the shield completely. Huge difference in light output.
Cleaned the chrome reflector bowl. It gets hazy and foggy after years of halogen bulb use and heat. Again big difference.
Remove the adjustment hardware. The adjuster nob unscrews all the way and releasing the spring and leveling rod. These springs get old and worn causing the housing to vibrate. Take the spring and stretch it out. Then install them back in for a snug fit and a lot less vibration from driving.
While I had the lens off I made a cover from a 12"x12" piece of acrylic from home depot. Traced the fog light lens and cut a left and right piece. Then applied a neon yellow film. And threw in some yellow coated bulbs for time being. Used a couple pieces of heavy duty velcro tape for removal and cleaning. If the film starts peeling or chipping I can take off the cover and apply a new film instead of applying it to the actual light on the truck. *lazy man's cover lol* (this is all temporary till a later set up. But was fun to do and works great)
Pretty nice deep 3000k color.
Against 6000k hids.^^^
What hid kit did you use?
05Single
05Single
afraid of the dark
It's a frankenstien mix of morimoto, glanz, and distinctive hids pieces lol.
Smoke Em All
Taylor,Texas
Have you ever used LED headlights? I'm considering them with projectors instead of hids
05Single
05Single
afraid of the dark
I plan on swapping to leds when I do a retrofit with projectors over the winter
Smoke Em All
Taylor,Texas
I'm trying to find a write up on retrofitting but haven't seen one yet.
cnut
I'm working on a retrofit now for my 04 Burb. I'll post some pics when I'm done.
Fosscore
@05Single
Interested to see this underglow. You've got the handle on the cool lighting mods. Like the blue. I switched to blue LEDs interior just for something different to match the Dark Ming Blue Metallic paint.
Old school low riders....still remember this guy had a Datsun painted orange, booming system, nearly scraping the bumps everywhere he was so low and bouncing all over the place with limo tinted windows...if I could only remember what name he had airbrushed on the rear window.
Looked very similar to this one, but only a single cab. I think he even had the chrome louvered visor. Thanks for the memory.
#1taho
5150TAHO
niagara falls ont
Never had underglow on any my vehicles, always wanted one. But it never makes it on my list of mods lol. Yea some call it rice from the fast and furious movies. But underglow is originally from the older lowrider and mini truckin days years before f&f. Those are the years I was grew up in.
So for now till I get a real kit I'll have this, not finished yet but it's the idea I'm going for. Later I'll buy a legit kit with multi color function with a more uniformed glow look. Yea I know kits are cheap but at $12 for 10 of these eagle eyes that's not bad for a diy homemade led kit. 2 or 4 on each side and 2 in front and 2 in rear.
As you can tell they're spot projectors style leds. So I'm trying to figure out a bracket to angle them and create a flood light that glows on the ground. But this gives an idea and visual, some of you might like this look too, I've thought about it, especially in white. But look how bright these bitches are even in the light
With parking lights on
With the mirror puddle lights retrofitted with white eagle eyes
Where did you get them ?
05Single
05Single
afraid of the dark
I've been in love with mini trucks and lowriders since I was a baby lol. Funny thing is I didn't grow up around them. Alaska wasn't and still isn't the type if place to have anything low. I just remember getting minitruckin and truckin mags in the mail and seeing these badass looking slammed trucks and falling in love with them. I was always modifying my hot wheels to lay frame , or model cars and trucks made to slammed.
I go with blue because we'll it is the coolest color for accessory lights , but also my tahoe being blue too. Green , yellow , or red , exc wouldn't really match. White would be nice but boring.
Smoke Em All
Taylor,Texas
What did you use to split open you door light housings? I want to open mine up but not trying to break it.
05Single
05Single
afraid of the dark
All but one fell apart when I tried to pop them out to put leds in them when I first got the truck. The glue was so brittle. But if yours are still holding strong I would heat them up with a heat gun and carefully pry them with a flat head. Cut along the edges with a razor knife to cut some.of the glue
05Single
05Single
afraid of the dark
Used these L brackets from home depot for mounts x8. Don't have to be pretty as they are hidden under the body. Already had wire and connectors. Bolts were 0.50€ a piece x8.
Drilled out
Wire it up, how you want. Make sure it's not hanging so it doesn't catch on anything like twigs, rocks, snow, cats, clowns, exc....
Can loosen and tighten and angle these straight down or up or at an angle like I did. You can also bolt them up to the rocker panel where holes are already existing for steps. But I wanted these tucked up higher
Taking care of that rust while I'm down here. Primer then spray can bed liner.
Anyway I'm at about $20 for everything.
05Single
05Single
afraid of the dark
Since I put them up high above the rocker panel gives it a nice cutoff.
Way brighter than I expected or wanted but I'll roll with it. Later I might face them up to see how much glow I get. Was gonna do the front and back but I think this is more than enough glow for me lol
HeavyHoe03
