Regearing my xfe tahoe
Nortex
We bought my wife a 09 tahoe with 3.08s.I really really dis-like the gears. I have 285/45/22 on it and want to know if I should go 3.73 or 4.11? It is a 6 speed 5.3 and we do a 50/50 mix of driving.
Sent from my SCH-S968C using Tapatalk
Sdog4127
3.08's, that's rough. It must practically idle at 70mph! 3.42's should give you about 2,000 rpm @80 mph, especially with the slightly larger wheel diameter you have over stock. I think 3.73 would be a good trade off, although I'm sure 4.10 for city driving would really pep it up. You would probably be running 2700 RPM or so @ 80 mph highway driving. I guess it depends on your preference... Good seat of the pants feeling when driving around town, or slightly better mileage when cruisin'
Good luck.
Sent from my iPhone 6s Plus using Tapatalk
DRC
Rocky Top, USA
If your towing, having lowers gear would be beneficial, if your driving mostly solo, I wouldn't bother.
Dropping to lower gears will affect your mileage, 342's, 373's would be ok, I would NOT go 411's.
N
Nortex
We decided on 3.73.
M3kanic
With the 6 speed transmission 3.42 are the same as 4.10. So going with that high of a gear is not beneficial unless you are going to be doing a lot of off roading.
The information about the gearing is around here somewhere.
Sent from my SM-G900V using Tapatalk
N
Nortex
Really! I was going off my 05 sierra which I know is a 4 speed. We do very little towing. I need to read this gearing info
EnigmaMan
One thing you should do is take a look at a transmission + rear gear calculator as one found here:
http://chevellestuff.net/tools/rpm_calculator.htm
GM 6-Speed 6L80 MYC Hydra-Matic Automatic Transmission (Standard Typical tranny on a 2014)
First: 4.03
Second: 2.36
Third: 1.53
Fourth: 1.15
Fifth: 0.85
Sixth: 0.67
Reverse: 3.06
You can see the final input / speed here in the attached photo.
3.08 vs 3.73 gears + 33" tire
Note: This does not take into account tranny slippage etc so your real world values may be off +/- ~100-200rpm
Note: I changed the gear ratios and is NOT using a TH700-R4 transmission and is using the 6 speed transmission gears that come with our rigs.
Hope this helps in gearing!
3.08 vs 4.11 gears + 33" tire
N
Nortex
We did 4.10 and love them.
Sent from my SM-S975L using Tapatalk
Jjdenali
Missouri
We pulled 21.5 at 70-75 on vacation
I was happy to get 16.6 with our denali on vacation. 4500 miles with all 5 kids and a luggage rack on the back. Lol that's going through Mt Rushmore, Yellowstone, Grand Tetons, valley of fire, red rock Canyon, lake mead, hoover dam, Canyon lands national park, arches national park, BLM land exploring in Utah, the mountainous drive back across I-70 to Missouri and everything in between lol we did drive 85 a lot through Montana.
worleytrev93
