yoshi's 05 tahoe build
yoshi
yoshi
nyc
flushed and changed transmission fluid as well as installing the transgo shift kit
out with the old
even got the cencom backlight hook up to the park to come on at night and off during the day
also the new mic hangers as well
yoshi
yoshi
nyc
Today i has finally taken care of a rust spot that has been bugging me for awhile and it also gave me the chance to paint the lower rockers black and i think it looks so much better. also this was my first time using bondo i know it could have came out better >_< lol
yoshi
yoshi
nyc
How's the new shift kit feel?
you can definitely feel the difference on that 1-2 shift, feels much better. i think next im gonna do the vett servo.
I was thinking of doing something like that or bedliner for them but i went with the x2 paint from rustoleum as a top coat after the rust converter gonna see how it holds up.
TheAutumnWind
All I have is the vette servo. Definitely a worthwhile upgrade on its own.
yoshi
yoshi
nyc
i really got to get on that and get it done soon,
on another note i found out why i lost 5th fan speed and i got some painting done while i was at it.
This last bolt to get the black cover off on the passenger side is the biggest pain as there is barley any space to get the socket in but once i get it everything else works out. i only took this off as i was replacing the driver side blend door as well. If your just doing the resistor you don't have to take that bolt out.
Got tired of the faded gray look time for flat black
Did you plastidip ? I have a shift kit in my express work van and it feels amazing ! What a difference. Doing the same to my Tahoe soon. Trans guy said I don't really need the vette servo.
Did you install the shift kit yourself? How bad/hard was it to do ?
05Single
afraid of the dark
I Plastidipped my lower valance piece black too. Looks so much better than that grey.
yoshi
yoshi
nyc
add in the post how it looks mounted forgot to add that picture yesterday
I used rustoleum pro 2 and then a semi gloss clear coat i think it matches abit better
yes you can just do the kit without the servo and it will still be good its just a nice little extra to add.
also this is my 2nd time doing it so a bit easier. just make sure to have the right drill bit sizes that it ask for in the manual and what i found to be the biggest pain was the bracket for the trans shift cable it gets in the way of dropping the pan but once you get around that you're good.
yeah it does that gray was just so faded and out of place looking i still have to paint the top part its looking abit faded black
TheAutumnWind
many shift kits include things that work similarly to the vette servo (like springs or spacers for the stock servo)
chadw
looks like youve been busy!
on an aside... you know its MIGHT as well, right? lol
Spencer_waynee
I've heard so many mixed responses about getting rid of the self levelers and not changing springs...how's does yours ride? Effect body roll any?
yoshi
yoshi
nyc
overall i have not felt much difference the most noticeable thing i have seen was that you get a more leveled look with the front handling feels fine. I might go out and get new spring once day when i get time. I was gonna try z71 springs but i hear you get a bit of lift out of them.
yoshi
yoshi
nyc
So i haven't been around in abit as my pc died now that its finally back up im gonna just make a big post with all the updates. I have taken a couple trips to pick n pull yards in pa and rl and they have been great
been able to find some little things i have been missing.
now for what's new,
go rhino push bar added (really well made i'm glad i bought it)
spot led bar added to the bar
straight intake taken from a 98 silverado( i feel like it has changed the intake sound a bit for the better and make a shorter path for air flow, also takes up so much less space than stock and cheaper than other options)
upper air box from the same silverado but with air cleaner gauge
trailer hitch need to get it sanded and painted
cargo door strap(it was missing since i bought the truck)
factory sub box rear (not installed yet)
all stepper motors replaced (gonna add the trans temp as its a plug and play mod from what i hear)
changed turn signal housing
Pic time lol
Man! I love the pushbar! Buy it new or used? I'm looking for the same style for my 03. I've been searching craigslist with no luck.
yoshi
yoshi
nyc
i bought it new from ebay they had a good deal. I know how that can be. I have seen it once on cl but someone beat me to it lol
Drewphil
