Quality lift kits?
whitey hoe
Are your keys turned up at all. I think I want my front to sit a little higher then yours is... not much just an inch or so. maybe its the angle of the picture.
Keys are cranked up all the way,one more inch would b great .I still have factory rake which works perfect when I tow 2 tons but other than that I would agree on one more inch in the front ,Z71 springs are the way to go either way
Patriot17763
Patriot17763
so what will the Z71 springs do for me? what key and spacer kit should I use? what could I do for that extra inch in the front?
Countryboy07
Z71 springs will stiffen up the rear and add 1/4"-1/2" in height depending on how much sag your stock springs have.
I bought my keys and spacers separate... Mainly because I wasn't sure what I was doing with the rear yet. Any leveling keys will work, I think mine were like $50 shipped. Then bought 1.5" billet aluminum coil spacers.
As far as the extra inch... Torsion bar age and wear play a huge role in how your particular vehicle will respond to the leveling keys. For example; my Yukon has just over 200,000 miles. My driver side adjusting bolt is turned in 1/4" more than the passenger side to achieve level in the front. That's just the way my bars wore.
Here's a crappy picture of mine, sitting at 38.5" in the front and 39.25" rear on 275/60/20 tires
Patriot17763
Patriot17763
If I go z71 springs do I need to do a specific z71 key up front since the rear height is different? Or just any key?
X-ray Nerd
