Lowering on 24's
Ghostl7
Corinth, MA
In the same boat! Already lowered with 3" coils on stock autoride shocks using shock extenders. Going 4" and need to know if I can use basic air shocks with air line run to manually air up?
NORCAL SS
SUV SUSPENSION GURU
4 inches will need my rear end link and bumpstop kit and cut bracket off frane
BADRIDES
which springs you have in rear?
redeknightjr
i have a adjustable kit 3-4 inch with shock extenders is 250 shipped
Tony, will the same 3-4 kit for an 07 Tahoe need your end links and bump stops? Or, can I get away with just the springs and shock extenders?
1SG Retired
NORCAL SS
SUV SUSPENSION GURU
1SG Retired
I'll be honest here. 3 inches or more I cutty bracket off. If it's a true inch spring if you have people in rear and sint cut bracket will just bounce.
Cut bracket off do endlinks and my bumpstops and your done.
redeknightjr
Thankyou sir
1SG Retired
Ghostl7
Corinth, MA
I'm ordering DJM LCA's in a week or so to get 3" drop plus the 2500HD keys will get me where I need to be.
Ghostl7
Corinth, MA
What kind of shocks you running? What's ground to fender on the rear?
I'm using stock autoride shocks with Truxxx extenders but will use Monroe MA830's or DJM 2000 shocks. In the front will have to be DJM 1315 due to the new shock location.
I'll get the measurements another day.
Ghostl7
Corinth, MA
Alrighty. I ordered DJM lower control arms, rear end kit (RK2000), Cal-max shocks front and back (1315,2000), front sway arm short links (EL01), rear bump stops (10R), and Moog upper control arms (CK80826). I'll be posting as much as I can as it comes in. Will take about 2 weeks for everything to ship in for some reason.
Can anybody sticky me a good link to deleting my autoride codes?
redeknightjr
You are on it. I had the DJM upper control arms on my last tahoe.....loved em
1SG Retired
AdrienR
