Front Lower Valance
Baggerjim
Wisconsin
I have an '08 Tahoe LTZ, does the front valance serve any real use or is it just for looks? I want to take it off for more ground clearance. I tow a 6000# travel trailer and I don't want to screw up any air flow that helps with cooling. Thanks
NathanJax
Vacation Nathan
Jax, Fl
just for looks
CrashTestDummy
Pearland, Texas
The front valence, or more-specifically, the front air dam actually directs air out from under the truck, reducing turbulence there, and helping MPG some. I haven't compared the vehicle with and without the airdam, but we put a front air dam from a NBS Suburban/Tahoe on our '02 Sierra 2500HD D/A and gained a solid MPG in all driving modes. Your mileage may vary. ;)
vinnyray
Lancaster, PA
I had mine off and on, doing several trials and couldn't notice a difference. If you drive a lot of highway you may see more of a drop removing it.
The other alternative is to trim it.
fiatdale
Houstons Best
Houston
If you do remove it, the bumper cover looks like shit without it. Youd want to trim the bottom of the cover off as well so it cleans it up.
dktrpepr
Colorado
Took the front valance off my '09 Tahoe LTZ and this is the look. I've noticed about .5 MPG drop but mostly city driving so not sure of the hwy MGP.
Next step will be to dremel off those little tabs for a clean look.
Conedaddy
