Ok, so i've been having hella problems with my Yukon and the brakes. everytime i get it fixed it seems to be another problem that arises. This is wha ti've replaced so far:
both front calipers
both front rotors
both front pads
both front brake lines
wheel cylinder
master cyclinder (twice)
abs pump
INitially, the brakes were locking up and i didn't know that the previous owner pulled the ABS light from the dash. The abs pump/ecu was throwing 13 codes, Thus, i had to replace it. Everything was better until it locked again....disocvered it was a rusted backing plate, creating play when the brakes were applyed causing the wheel cylinder to pop out and not return to its resting position. THe place i took it to bled the abs pump too.
Now, i just replaced the master cylinder again because the pedal is too mushy and when i press the brakes the brake light came on. Bench bled the master cylinder, Bled the system, was a hair better, but now the spongy brakes are back again and the light is back on.
No drips, no leaks (that i can see)...no idea.
One thing i did notice, however, is that I put brand new fluid in he entire system...bled out all the old fluid. But now the fluid is extremely dirty...
Could this be a bad brake booster?? Thats the ONLY thing that hasn't been replaced
My thoughts is tha ti wanna get rid of this entire abs system...can it be done??
both front calipers
both front rotors
both front pads
wheel cylinder
abs pump
