MM60
- Joined
- Jan 10, 2024
- Posts
- 4
- Reaction score
- 3
Replaced both front rubber brake lines, calipers (slide pins lubed), pads, rotors, master cylinder, flushed all the fluid (which was dark) and bled brakes in the correct order. Front brakes heated up and began dragging once again on both sides. I checked my booster and it is working properly. The old master cylinders piston area was half eaten away. The black plunger gasket seal was half gone and dirty. I checked the booster and it's working properly. The dragging occurs after driving for about 20 minutes. In the mornings, it starts and drives fine until the brakes warm up. Then the drag occurs. This is driving me nuts, not to mention my wallet!
