2011 Avalanche Build (Wrecked)
David Smith
David Smith
Savannah, GA
So the cruise control light on the steering wheel will still light up. I tried to set the cruise, but it will not set. I did not see the traction control error, but I only drove like 3 miles. Maybe a bad brake pedal sensor? All brake lights work as they should.
David Smith
David Smith
Savannah, GA
Been driving the Avalanche around. It rides SOOOO much better than my Tahoe did. It is crazy. Everything works flawless, but I think I am going to throw on a new brake pedal switch to see if that fixes the cruise control. Would the brake lights still function normally if the switch was bad?
Yes. Don't try to fix the contacts or buy an aftermarket one, stick with GM OE or ACDELCO.
My cruise has not worked a few times. The brake lights stilled worked, though. I found that if I jab the brake pedal one good time and/or pull back on it with my foot behind it, the cruise will work again.
Buzarr
