05Single
afraid of the dark
- Joined
- Feb 26, 2015
- Posts
- 8,183
- Reaction score
- 11,449
You can touch it if you want....touch it all over redCan't touch that comment.
Do you think maybe they're made like that on purpose?Yeah every pic of a cubby I've ever seen its always warped. It bothers me a little. Plan to heat it up and square it off later....maybe
Totally makes sense now.So all the cubbys I've ever seen came out of center consoles with the air vents next to them..I think the heat makes them warp. This is why the vents are low by the feet on models with rear audio because there would be too much heat in one spot from having the controls and vents next to each other.
Mine is half that size and in the Denali's there's no vents nearby. Still warped.So all the cubbys I've ever seen came out of center consoles with the air vents next to them..I think the heat makes them warp. This is why the vents are low by the feet on models with rear audio because there would be too much heat in one spot from having the controls and vents next to each other.
I would assume yours came with rear audio. But being a 02 I'm not sure. Never know about these trucks and all the infinite optionsMine is half that size and in the Denali's there's no vents nearby. Still warped.
Yeah it had rear audio controls which I removed and installed the cubby in it's place.I would assume yours came with rear audio. But being a 02 I'm not sure. Never know about these trucks and all the infinite options
Oh so it came from another truck. That's what I meant. Original truck with vents on the side.Yeah it had rear audio controls which I removed and installed the cubby in it's place.
