2014 Yukon XL airbag recall notice
CiscoKid
Virginia
Just got it in the mail. Passenger side airbag recall notice. Vehicle is a 2014 Yukon XL with roughly 78,000 miles on it. Very good condition.
I have a couple of questions.
Do they have to pull the dash to do this repair? Just how intrusive is this job? I don't want to get it back with rattles.
If I do decide to get this work done, should I pull the AFM Range Disabler before dropping it off?
Is this something I really need to be concerned about?
They do not pull the dash, they take the trim piece off that goes across the front, drop the glove box down, pull out the right side vent outlet, unbolt and R&R the airbag, put it back together. a experienced tech can do it pretty quickly
C
CiscoKid
Virginia
Thanks. If they had to pull the dash, I'm not sure I would go ahead with it. Still not sure if I will or not, but that makes me feel better about the job.
I'm in the same position. I've got a stack of these notices on my desk. I will go ahead and get the work done soon, as my wife no longer wants to ride in the truck, until the work has been completed.
I had the one done in my Silverado, it was fast. I’ve pulled that airbag a couple times myself. It’s just held in with (4) 10mm bolts and the cover just unsnaps from the dash as you push it up.
St. Louis
Shackman7878
San Bernardino
I am guessing the same process maybe a different part numbers. looked up a 13 tahoe
attached the most up to date on the recall looked up a 2011 Suburban
  • MC-10137534-9999 update.pdf
I love how they state that “some” of the dashes might exhibit cracks around the airbag opening due to “age and environmental exposure” instead of what we all know- nearly all of them will be cracked due to ****** design and plastic but I guess they’ll never admit that will they? And of course it’s not covered.
“Due to age and environmental exposure, some vehicles may display warping or cracking around the passenger airbag opening in the upper instrument panel area. Inspect this area with the customer at the time of the vehicle repair order write up. If warping or cracking is found, inform the customer that the condition is not covered by this recall, nor is it caused by the airbag service procedure. This warping or cracking condition will not affect the passenger side airbag deployment”
Jax01984
