2004YukonXLDenali
Banned
I have been doing some research on how to disable the TPS when aftermarket Wheels are installed. None of us want to pay $99 a sensor for our new Giovanna's. I found a way to disable them but I need some back up before I try it. So there is plastic cover right below the glove box remove screw and pull down you going to see a little green box (tire pressure monitor ECU)it has plug with 16 wires look for the #6(when you unplug and looking at the plug in front of you star #1 top left corner and #9 should be right below that anyway is the blue wire you need to cut this and ground the wire going to the bulb or light not the one for the little box and the light goes off even with one of your OEM wheels and tires flat. Have any of you guys heard of this?? This is just what I found searching the internet. I have no clue if it would work or not.
