Fosscore
Don't know if I'm going to color match it just yet. Might just try to paint the chrome the same metallic gray.... will need a few cans of etching primer, do the front and rear bumpers, but I think it'll come out 'aight!
Gonna pull the roof rack and the six bars, do them all too.
Yeah that sounds great too. Even if not color matched, it will tie in with your color scheme/contrast nicely just like the grille.
bottomline2000
Dallas, TX
I can't say for sure if they have resolved the overheating and melting issues yet. I can say for certain though that I have not had a single issue with my OEM harness that I got from a 06 Silverado. I've had my E-fans wired up with an OEM harness for over 6 years now and the summers here in Louisiana can be pretty brutal. We regularly have triple digit temperatures, and sometimes for over a month straight. And even in these extreme temps, I have not seen even a hint of any melting on my harness or relays. But as far as the Nelson harness and the LS1FANS harnesses, I have seen quite a few people online who have had problems with the relays and/or the relay plugs melting. I have not seen anyone post about it in about the last year, so I honestly don't know if Nelson has resolved the overheating problems or not.
@ScottyBoy, do you know the purpose of the diodes on the factory harness. I've seen you run the factory harness for years with no issues and wondered if the diodes helped.
05Single
afraid of the dark
Out of curiosity, how long did it take you to pull the parts off?
Mine took a little longer cause of the corrosion form the winters. But in places like Texas and az should come apart pretty easily.
griffey_mojo
