05Single's virgin build thread. 03 tahoe
05Single
05Single
afraid of the dark
HD grille. Trimmed the lower part a little more than an inch. There's a middle bracket. Trimmed that as well and kept it for extra support. Everyone asks how much need to be trimmed. Well after I did mine it's hard to measure exactly so I trimmed it to where it's flush with the lower mounting tabs.
You can see the middle brace that bolts on the back side along with the bowtie. It hangs down. I was able to slide that part behind the bumper pad but it wouldn't pop the rivet into place.
You can also see where the trimmed part is flush with the outer mounting spots.
05Single
05Single
afraid of the dark
Swapped out a pretty clean fram filter for a k&n panel.
20170813_032907.jpg 20170813_032941.jpg 20170813_032945.jpg 20170813_033100.jpg
2 miles later I immediately get the infamous check engine light:smh:
Only lightly oiled one side, the dirty side. Might take it out and clean it and run it dry, should be OK ?:shrug:20170814_125951.jpg
05Single
05Single
afraid of the dark
Got new shoes. 2011'ish Denali 20s on bald tires. You don't wanna know how much I paid for them. But hey they look clean. Get new rubber this fall.
Loaded them up in my cousins Silverado. He's gonna buy those black Denali 20s we set next to his wheels.
I thought 20's would look bigger than 18s. But they were only 2 inches bigger. So now I want 22s:hmm:
View attachment 181588 View attachment 181589 View attachment 181590 View attachment 181591
Only lightly oiled one side, the dirty side. Might take it out and clean it and run it dry, should be OK ?:shrug:View attachment 181592
If it's not oiled it's not filtering good. Did you follow the instructions as far as amount of oil and let it sit awhile? I've never had a problem with 2 different oiled filters.
05Single
05Single
afraid of the dark
Maybe 03 system is more sensitive. My 05 silverado did the same thing. No running issues tho :shrug:
juniordaboi909
