ZW7 Premium Smooth Ride?
TollKeeper
Brighton, CO
Build sheet aside, what are your "Axx" RPO codes in the glovebox?
A31 - POWER WINDOWS W/DR EXPRESS DOWN
AG1 - ADJUSTER FRT ST POWER, MULTI- DIRECTIONAL, DRIVER
AG2 - ADJUSTER PASS ST POWER, MULTI- DIRECTIONAL
AJ1 - DEEP TINTED GLASS
AJ7 - SIDE IMPACT AIR BAGS
AL0 - PASSENGER DETECTOR
AL4 - SECOND ROW BUCKET SEATS W/HEAT
AL4 - SUSPENSION, FIRM RIDE HANDLING,FRONT AND REAR
AN3 - POWER HEATED BUCKET SEATS WITH DRIVER MEMORY
ARL - PLANT CODE ARLINGTON, TX USA
AS3 - 3RD ROW 50/50 SPLIT BENCH SEAT
AU0 - REMOTE KEYLESS ENTRY
AXP - VIN IDENT POSITION, MULTI- PURPOSE VEHICLE
Not at my truck currently, at work. Will look to confirm in a bit
TollKeeper
Brighton, CO
Other than the double AL4, it appears identical to the build sheet I got from GM
Weird. Do your second row buckets have heat, as described in the build sheet? My '04 has AL4 but no heat in the 2nd row buckets.
TollKeeper
Brighton, CO
Heated buckets or bench seats were available on the Denali or Esky
I seem to remember cooled rear seats are available on the Esky Plat
K2 Kaiju
The Depths
"Premium smooth ride" is just the name for the stock suspension most mid models received - no electric dampening. The Z71 system is stiffer for offroad, while "autoride" was the one that should have been called premium smooth ride (magnaride is an even more advanced version of autoride on the eskys back then). It costs a lot to replace, and only lasts 50-70k miles, but it is a lot smoother riding. I went with premium smooth ride on my current rig (from autoride before) to save money in long term maintence, and allow for bilstein 5100s or a lift. It bounces quite a bit more. Bilsteins will be my next upgrade...
Luggz
