Z55 RPO OE front shock/strut 2014 yukon denali
rower51
Not able to find original equipment replacement front strut/shocks for a 2014 Yukon Denali.
Would like to keep the original electronic adjustment ride control and not bypassing it with a resistor and standard shock setup.
Does anyone have a source for Z55 RPO code OE shocks?
Thanks
RockAuto.com and GMPartsDirect.com should have your OEM replacement shocks. You can select them specifically by entering your VIN and using the RPO codes on your glove box sticker to match up ===>>> Z55 and 6xx and 7xx codes . GMPartsDirect.com has prices significantly lower prices than your local dealer.
The front springs on my 07 Yukon XL Denali are no longer manufactured by GM, so I used a Moog spring with the correct part number cross reference, and they have worked out fine for me.
petethepug
Michael
SoCal
It’s one of these two…
Add the parts in below less the z95 struts listed …
Sent you a pm regarding a few more parts.
kikeap
