Xl max delete king upgrade question
Fifty
im done. I can’t stand these crap mrc and the fronts are just getting so bad.
I am going to do the mrc delete but I want to run King 2.5 coilovers in the front and 2.5 piggybacks in the rear.
I want the extra fluid capacity over the 2.0’s due to the weight of the vehicle.
I am debating lifting just a little bit. Only if it afforded more travel, not height alone. I think they have an extended travel set up with a new upper arm that adds an inch or two travel up front for the Silverado 1500.
So my question is, are people just ordering as if it’s a suburban? Or Silverado 1500 front and then measuring the extended and compressed stock rear shock lengths and trying to get close to that?
F
Fifty
I did, they were not sure at first. But I have since figured that it will take the similar year burban or xl and for the front you "should' get the upper control arms to maximize travel. I ran into a hiccup with my ZR2 and needed to dump some money into that. Otherwise the XL would be riding on Kings right now.
As much as I want to do 3.0's front and rear due to the weight it will add almost $2500...effectivly doubling the cost...
Tiki
You can run stock UCAs. I ran Cognito UCAs with ball joints.
mfinta
