wont stay running
DallasTahoe
My tahoe has been sitting for about two months and i went out to start it, had to charge the battery upwhen i was able to get it ready to start, it would only run for about 3-5 seconds, everytime. I had this*issue about*5 years ago and they said it was something*having to do with*the*ignition*switch*not linking up, it had to be flashed or something like that, my question is, is there anything i can do without sending it to the shop again and*spending*$300 again????
Thanks in advance
ccapehartusarmyINF.(ret)
Gilbert AZ
what year is the vehicle and turn the key all the way on without turning in over and see if you can here a whine of the fuel pump priming if you dont hear it its possibly the fuel pump id change yer fuel filter first
DallasTahoe
DallasTahoe
I thought that the first time it happened but after i had took it to the shop its some kind of syncing problem with the ignition
Ep33401
