Wireless charging issues- iPhone 14 pro
Vinnoto1
Hello,
Recently purchased a 2022 Yukon Denali XL with wireless charging included.
Wireless charger worked fine with my iPhone 12 in its case, tested with multiple phones.
After getting the 14 pro it would not work with or without a case. It just keeps turning on and off.
After some google searches I found this is a major flaw from Apple due to the camera bump, only affecting the iPhone 14 pro not the pro max. The camera bump causes to large of a gap between the charging pad and magnets in the phone.
I tried adding a MagSafe case which has additional magnets in the case for charging and other attachments, no luck there.
Now I’m using a wired connection which is also forcing my phone to use wired car play and the wireless auto play is not really working anymore.
This is aggravating and I understand it’s Apple problem and hopefully they will come up with a solution whether it be an adapter or special case to correct the issue ( doubtful)
For now I plan to get an apple usb c MagSafe charger to lay in the charging dock so I can still do wireless charging and wireless Apple car play.
Has anyone else come across this and found any workaround for this issue?
Thank you in advance!!!
pa31p
My Iphone 13 mini has the same issue. camera hump and won’t charge wirelessly. wireless carplay works with cable plugged in for me no problem so it’s possible but…i’m using the usb-c port from the center console.
Reels
Senior Member
Wow, thanks for reporting that. I would not have seen that one coming... Hopefully you find a good solution.
Saltydog
I have 14 Pro Max, going to see if it will charge of course that will require cleaning the charging pad area out as my wife uses it for storage :rolleyes:
I use the wired CarPlay as I am not happy with the wireless CarPlay as it seems laggy and it tends to disconnect a lot.
Vinnoto1
Vinnoto1
Is there a benefit to wireless Carplay vs wired Carplay? Just curious...
The issue I found is now my car is waiting for the cable to be plugged in to use it vs immediately connecting wireless. I’m not always charging the phone in the car so I’d like to be on wireless for CarPlay and not tied to the usb cable.
For reference I was using the usb A port. I will try it out with the usb C when I get a chance and see if I can adjust the settings.
Pertzbro
use a regular house 110 charging block in the 110 outlet and you can skip the carplay if you'd want. Then you can charge it and still have bluetooth...
StephenPT
St. Helens, OR
Ah - that makes sense. It's probably already connected once you open the door and the rig starts to wake up. Plus if it's in your pocket it's connected and you don't have to take it out just for Carplay. Got it - thanks!
imfrogman
install this, will solve your problem and work much better than factory charger
Vinnoto1
Vinnoto1
My only hesitation with this device is it may present the same problem as the issue is the phone not the stock wireless charger.
imfrogman
It works without any issues, i even have a case on my 14 and it charges without any issues. IMO this is where gm should have put the wireless charger
Vinnoto1
Vinnoto1
Is it an iPhone 14 or 14 pro? Currently the issue is only on the pro due to the camera.
imfrogman
Its a pro, i can even lift the phone completely off the pad about 1/4 inch and it still is charging. Plus the added benefit is that it is a fast charge unlike the factory charger. look at the youtube video reviews
SmokeyJoe
2022 Tahoe LT, Samsung 10+. Iphone 12. When I try to charge the S10 using the wireless charger, the Infotainment screen indicates it is charging, the phone indicates it's charging but if the phone was at say, 50%, after a couple of hours it would still be be at 50% and a little while after that I would get a message the the charger was overheating and I needed to remove the phone from the charger. Pretty much same for the Iphone but haven't left it on as long as the S10.
Am I the only one with this kind of problem? Anybody got an idea?
Bkihum
Champion Ohio
Hello,
Not sure about 14 pro wireless charging issue but just purchased same phone yesterday and just tried it and there was no problem.not sure Apple would change anything to fix vehicle problem.
Harry22
I have a 22 Burb. Does anyone make a replacement rubber cover that sits in the factory charging tray? I have a Samsung and my wife has an Apple phone. Both experience the on/off charging issue. I took both phones out of their cases, same problem. I removed the rubber cover (simply pulls right out) from the charging tray and both phones charged with no problems even with the Otterbox cases installed. The rubber tray seems a bit thick?
Danimalx87
