will this navi work in my 09 burban
OklabyGodhoma
Normal....er, Norman, Oklahoma
This is a never ending question. First off the answer is a definite maybe. Do you have a Bose sound system? If so then you are home free....install and enjoy. If not, then you have a few problems to overcome. I'll wait for your answer and then go from there.
B
Blackburban09
no i do not i have a suburban Lt with blue tooth my speaker grilles do not say bose so that means i do not have it right ?
OklabyGodhoma
It means that should you get the stealership to program the radio it will only have one set low volume level and you won't have any chimes, turn signal sound, etc. The unit you bought is the high end unit and I have been working on a solution to this problem from recently gained information. Bottom line.....don't give up just yet, there may be light at the end of this tunnel.
Wish that before you had pulled the trigger on this you had taken the time to research the forun since this has been a well cussed and discussed topic for a couple of years now. You might go ahead and read all the threads on this topic and get more up to speed so you can see all the viable choices to date.
Sorry to have to give you the bad news.
B
Blackburban09
I actually returned it so I lucked out so what do you suggest I do for a nav then buy the one for non bose?
AdrienR
