Blackburban09
- Joined
- Nov 9, 2010
- Posts
- 71
- Reaction score
- 1
i wanted to know if the 25797978 nav unit will work in my 09 burban thanks guys
It means that should you get the stealership to program the radio it will only have one set low volume level and you won't have any chimes, turn signal sound, etc. The unit you bought is the high end unit and I have been working on a solution to this problem from recently gained information. Bottom line.....don't give up just yet, there may be light at the end of this tunnel.
Wish that before you had pulled the trigger on this you had taken the time to research the forun since this has been a well cussed and discussed topic for a couple of years now. You might go ahead and read all the threads on this topic and get more up to speed so you can see all the viable choices to date.
Sorry to have to give you the bad news.
