Will a Kenwood or Rockville powered Sub fit inside the Center console? NNBS 07-13
trailblazer
I scoured the internets on this and I can’t find any photos. If I pull up the center console will either the Rockville SS8P or Kenwood KSC-SW11 fit in there? I saw a thread with photos for the 99-06 Tahoe but nothing for the NNBS. I am not looking to bump like the boys in the hood I just want some better sound up front for under $100.
Rockville SS8P is 11.4 x 8.3 x 2.8 $80
Kenwood KSC-SW11 is 11 x 7.5 x 2.8 and is $47 more than the Rockville.
Keanen55
HOUSTON, TX
Not sure if that will work without some trimming. It's not just a square clearance under the console. They use to make custom boxes for that (MTX and JL audio). Theres a seller on Ebay that still make boxes. Here are the measurements for the MTX box. Good luck
11"D x 22-5/8"L x 6-1/2"H
T
trailblazer
Geoffsfas10
St. Louis
No its for ours. let me know how the install goes and how you like it...im trying to convince myself i DONT need to do this.....haha
T
trailblazer
Even a moderate gain in bass would be substantial. I only last week installed new rear speakers as the old ones have been dead for years per the previous owner. I watched a YT video and installed foam baffles along with the replacement 6.5” Pioneers to protect them from water. What a dumb GM design to not even put plastic over them.
T
trailblazer
That's old news... every amp I have ever bought had a built in amplifier...;)
Lol good catch I meant the SUBWOOFER with the built in amp. I just saw that Rockville (factory direct) is selling refurb versions for $76 with free shipping. If this works out good for my Tahoe I’ll put one in my 2500HD too.
T
trailblazer
Anyone know what this wire is for? I do not have the Bose option. I popped off the center console tray and saw it taped up from the factory.
Geoffsfas10
St. Louis
I dont know what thats for, but i like that there seems to be progress being made towards this
T
trailblazer
It was at about 1600 yesterday when I finished my other projects and decided to take a swing at this. After realizing that I must pull both front seats to lift the center console out I put the brakes on it again. Maybe on my next set of off-days I’ll revisit this project beginning at 7AM.
Kee Fuller
las vegas
I have a fiberglass front center console enclosure with a 10 inch mtx speaker that came out of my 2013 tahoe available . You will need a amp for this sub woofer . I used a 300 watt amp .
How much you lookimg to get rid of it?
T
trailblazer
Just finished the installation. Took about three hours working at my slow pace.
Used an E18 and E14 socket to remove the front seat front nuts and rear bolts. I didn’t actually remove the seats; just lifted them slightly lateral of the mounting points. Then I simply pulled the console back. This part only took about 8 minutes.
There is plenty of room for the Rockville SS8P. Just note that the closer you place it toward the firewall, the tighter the console gets. I wanted it far enough forward so I could still adjust the screws via the removal console side panel.
The wiring took the longest. I ended up just using the mystery wire connector circuit which was confirmed to be AUX PWR2, a 20-Amp fused circuit that is constantly hot. I decided to use the blue wire on the Rockville harness and connected to an ACC wire located in the panel near the driver left foot.
I pulled the radio and used the solderless quick splice connectors to attach some 22 AWG speaker wire from the radio connector to the Rockville harness for the speaker high level inputs (to the front speakers).
Everything looks clean and is still quite accessible.
T
trailblazer
It sounds very good. I had to hit the phase button as there was a slight delay but it sounds fine now. I had to take it out of service to do and oil change and such but I’ll swap it out tomorrow morning to really give it a good test; maybe I’ll hit the brown note.
Geoffsfas10
St. Louis
So I want to make sure I have your wiring right...
This is in a NON-BOSE truck right? You used the mystery wire as power for the sub, then tapped the radio for signal. Then you are using a ( random ) ACC wire in that drivers footwell distrubition block as your remote wire ti actually turn it on and off? That sound right?
So on a bose truck, you would do that same thing but the factory high level connections for the sub would be reused for this sub.
T
trailblazer
It’s non-Bose. I could have also tapped into an ACC controlled wire on the radio harness. The “random wire” goes to a cigarette lighter plug circuit for the split bench seat which I do not have. It’s a fused 20A circuit. Seems to provide enough power and I do not hear any line noise.
Meccanoble
Georgia
A 12" would fit down there with the right custom work but a box with the necessary cubic space may not. The biggest sub I seen someone fit down there was a Kicker L series 10". I forget the dimensions down there but for guaranteed cubic space, I would focus on maximum 10" sub.
wwiizz
