Disclaimer: Links on this page pointing
to Amazon, eBay and other sites may include affiliate code. If you click them and
make a purchase, we may earn a small commission.
I am faily sure it will bolt up, but I've done some reading around the net and LS1tech and the answer I can find is that you will lose some bottom end torque. The gain would be all top end with bottom end loss.
Its not worth the money for the minimal upper RPM gains...esp with the loss of low end. But to answer your question yes it will bolt up. Just make sure you have the coolant crossover tubes for the LS6 also.
This site uses cookies to help personalise content, tailor your experience and to keep you logged in if you register.
By continuing to use this site, you are consenting to our use of cookies.
