Who turns on both A/C front and rear when riding alone or two people what is correct way
Jorge1313
What is better for vehicle too use front or and rear a/c when riding alone or with two people , or can I just turn on front. Is there any harm done if only use front a/c when riding alone cause it works harder to cool who’ll vechile. I just find it fine front a/c when I’m cruising or I’m doing this wrong. Someone told me they use front and rear when driving alone to cool vehicle better. I never use rear a/c am I wrong maybe giving it use so it doesn’t break.
UrbanSuburban
It really comes down to your comfort and your passengers. The system front and rear both use the same compressor so your not really wearing anything out and its ok to use. I use both because it cools down faster. Now the Heat in Winter is different. I only use the front until the engine heats up a bit and then turn on the rear but I find the climate control on auto works the best.
For Florida Jorge, run both systems. Set the temp to your liking and leave it. I set mine to 68 during the cooler months and 64-66 during the summer. My truck is black.
Running both keeps the systems working at a lower duty cycle, cools the cab off quicker and keeps it cooler as doors and windows are opened and closed.
Big Mama
Virginia
In Virginia it’s cooler so I usually just use the front. In winter or really hot days the remote start gets the car to temp before getting in it.
cardude2000
I turn off everything except a single vent in the back and keep the system on high.
homesick
The Best Me I Can Be
Navy Air Force
I agree, and would add that most any system, this one included, should be run some, not left to deteriorate.
joe
Mechanically wise on the A/C pump it wont make a shred of difference since it runs the entire system if it is on. There is no valve or control to make the Freon not go to the rear, it makes a loop thru the entire system when it is on. all your doing at the hvac control is turning electric blower motors on or off and adjusting the temp via the actuator door angle. The A/C pump runs 100% no matter what you do at the hvac control. At best the auto climate control turns the A/C pump off when the commanded temp is reached and then turns it back on as needed to maintain the commanded temperature.
Miami-Dade
Moderator Supporting Member
I very rarely turn on my rear a/c unless someone is back there. The front one has been on constantly since I bought my Tahoe. I set the front at 70. On long trips I drop it down to 68. I really should turn on the rear a/c more often when I get into it to cool it down quicker.
Tint and a sunshade on the windshield really make a difference when sitting out in this jungle heat. I use the sunshade everyday all year long to keep the sun off my dash and leather.
Glisella
NY, Westchester/Putnam border.
Both all the time. As others have said, ac blowing out the front and hot air on the back of my neck is not comfortable. (Vica versa in winter with hot front cold rear)
Windows down and roof open to let the bass out.
Fur reel, dough, I never gave this a thought and just turned the rear A/C off if nobody was back there. Leaving it on to cool the whole cabin makes good sense. Now I'm gonna have to sit in each seat, do some Manual N calculations and optimally aim each vent.
GTNator
Senior Member
Both, all the time. I have turned off the rear before but everytime I hit "auto" the system re-engages the rear system too, so now I just leave it.
mountie
Summer in Florida, if I have to park all day under the Sun, I unlock, then open the rear hatch, driver's side-passenger door then driver's door. Start truck. Then close doors & hatch. ( Much of heat is out)..
I then use front & rear blowers. Shortly after I turn off rear blower.
I love my Weathertech rain guards to vent heat.
( owner's manual actually suggest to open windows for a bit, when first turning on A/C )
cardude2000
Another fact based contrarian!!
Drewphil
