Who has the highest miles thread.
jayte184
I have a 2003 Denali with 82,000, bought her in 2008 with 68,000.. Fuel pump about a year ago and regular maintenance... Still running strong
gbert06
Amarillo, Texas
2000 nbs
256,500 mi...I always use 5Qts Castrol 5w-30 synthetic and a Qt of Lucas. I use wix or k&n oil filters. She still runs like a dream. I Take her to Dallas every couple of months. around 800miles round trip. She uses about half a Qt every 5000miles only because of a small oil pan leak. Other than that shes perfect.
DefendHawaii
Snake Eater
Kahala HI/ Seattle WA
What year is yours? Replaced trans or anything?
gbert06
Amarillo, Texas
It's a 2000 new body style. LS 5.3. Same engine block. Previous owner said it was the original transmission. Although i cant prove it, the fluid was nasty with more than normal shavings in the pan when I replaced both shift solenoids last weekend. Shifts smooth. Previous owner put in a bosch fuel pump and re-did the frontend along with a waterpump. Last year I replaced the a/c compressor and put in a remote start/alarm/keyless entry system and hid's. This year I replaced front and rear rotors/pads and dropped in a magnaflow exhaust. Surprisingly enough everything works as it should.
DefendHawaii
Snake Eater
Thanks. Mines got both original trans and motor as far as I know. I think my trans needs a little tune up as shifting in 4th on freeway stutters a little when it's winter time.
gbert06
Amarillo, Texas
Oh really?? Use a bottle of Trans-X. That stuff works wonders. I put in a bottle when i did my solenoids. Sounds like it just needs a basic trans flush and filter change. I believe there is a control solenoid also. I should have done that one on mine but completely forgot.
knoslf
Thornton, CO
I gotta 99 Yukon slt with 243,000 miles on her and although she can use some tlc, she still sounds like a sewing machine at idle!
sparks
Tampa, FL
traded my 02 escalade awd in a month ago with 285,500 on it. now im in an 02 denali with 76000
Chads93GT
St. Louis, MO
mine
Chads93GT
St. Louis, MO
Chad is that an OBS?? Thats a bunch of miles. Have you had to replace a lot?
replaced the fuel pump, 3 hubs, 3 u joints, some smog crap, ac compressor, rear expansion valve for ac, 3 batteries, 1 alternator, 1 thermostat, 1 idler pully, 1 belt, uhhhh........1 air filter........ a buttload of oil changes and fuel filters, 2 sets of shocks and a shit load of tires. Never touched the engine or the transmission.
---------- Post added at 04:34 PM ---------- Previous post was at 04:34 PM ----------
OH, and OBS?
Its a 2001 LT. had it for 6 years. bought it with 100,601 miles
samwilkie
Cleveland,TN
My 03 tahoe has 149xxx still running great. Theres a guy thats stops in at my work that just turned over 340xxx and never had any problems.. i love the 5.3..
johnsonwillie199
