Whipple Supercharger eating belts
Charged Tahoe
Hey Guys,
I have had my '95 for a couple years now and it always eats belts every couple months. I have taken it to 4 different mechanics. Even a hot rod shop. Apparently it is a common problem with this first gen charger and Whipple is well aware of it. I am looking to see if anybody has made a new bracket for the tensioner so the belt doesnt rub the tensioner. Basically, the speed shop guy said I need to find somebody to fabricate a bracket to allow the tensioner to go in further so the belt doesnt rub. Its not a belt alignment issue, I have explored that option to death. I use the gates HD belt, green.
Let me know, would love to make this truck more reliable.!!!!
-T
Dantheman1540
Sugar Loaf Mountain
99.9% of the time it is an alignment issue that's the only time I've throw a belt with my magnusson setup. However if something is rubbing the belt then of course it will shred them more often.
Post pics please.
gat0r
DFW
pics would def. help , as mentioned above
so alignment was checked w/ laser?
also other issue is fixed tensioner. one w/ spring tension that can adjust itself would be better.
iCajun
I ran one on my 1988 454 for about 20 years and never had belt issues. Any chance the belt idler pulley bearings are worn out?
Have you tried a spacer behind the tensioner mounting or grind the surface down depending on which way it needs to go?
SAUDADES333
