Whining sound from the engine
Iceman3000
I have a whining sound from engine. I thought it was the fan belt but I replaced it and it only quieted the noise slightly. Has anyone had or heard of this problem.
2000 GMC Yukon SLT
5.3 VORTEC Barn Door
THE-HOE
Pittsburgh Pa
are you sure its the motor,,,,, there is such thing as tranny wine... My tahoe had horrible tranny wine with its stock tranny.
Thumper8302
OKC, OK
im not sure on my thought but i think i have read somethin somewhere were some of us (yukons, burbs, hoes) have service bulletins on what u are describing... i have an 01 kon with the 5.3 and 230xxx miles on it and when its really cold or high humidity my belts squeal like a ***** and i find it rather embarrassing.. but it has somethin to do with one or some of the pulleys being out of alignment which would require some sort of laser alignment tool.. and as far as ur wiring issue i have no clue
matt14
san leandro,ca
As far as the whining noise goes, it could be a idler or tensioner pulley for the drive belt. Or maybe you have a p/s pump, alt, water pump going out. Disconnect the drive belt and spin each pulley. If you can hear the noise or feel "grinding" repalce that pulley or part.
Not sure what to tell you about the electrical problem. sorry
I
Iceman3000
Not sure... did the tranny wine change when switching gears or was it a constant whine.
---------- Post added at 09:20 PM ---------- Previous post was at 09:19 PM ----------
Mine gets real bad when its cold or moisture like rain or even washing the truck...
jomulk56
Resident Lurker
IN
Excellent advice there. My old GMC Canyon squealed like no other, and ended up being the idler pulley.
DanS
Delaware
my 01 Yukon XL has the same whinning sound but it comes and goes, but I really notice it when I'm excellerating
puckhead
CO
100% postivie its coming from the engine? Its not a whine thats coming through the speakers or anything? Could be a ground issue. Just making sure you covered all the bases.
yukonjacks
A Vegitative State
The Confluence
Mine began when I changed alt. idler and tensioner. Not sure which one it is, I'm thinking cheap after market alt.
DDUB
Georgia
i have a slight whine coming from my power steering pump nobody else in the hoe seems to hear it but it drive me crazy... go with what matt said its gotta be one of them ;) GL
Bentley95
