which fuse to tap for switched power?
jlatenight
Hi all, Is there a fuse I can tap off of (add-a-fuse) for switched power (only hot when iginition's on) in the fuse panel at the end of the dashboard on the driver's side? Anyone know which number is only hot with ignition on? THx in advance!
blaqout
King Yukon
Indianapolis
you should try one of the pink wires under the steering column on the floorboard next to the brake. There is a small box down there.
AdrienR
