Where ?
val620
Bay area
I finally have time to install my sounds but where is the best pace to run my power wire thru ill be using 0' gauge.I want a stealth install because I live in a not so good part of town and I dont want to give someone a reason to snoop around.So where do you guys usually run it thru?
grnrpr68
Davenport IA
i ran mine dowm along the frame and thru the floor in the back 0gauge it really think so i didnt want to go under the carpet just tie it up outta the way and not to moving parts you will be fine
xX Mavr1ck Xx
Middle Tennessee
the driver side thru the floor panels. run it thru the firewall.
x2 thats what I did,
Ingnore the yellow circle
DJTricky
Banned
Robbinsdale MN
i ran all 4 runs (2 positive and 2 neg) inside the frame rail on passenger side.you cant even tell with out getting under the truck
tast101
Colton, CA
I ran my wire down the center on one side of the console, but it's not 0 ga.
DJTricky
Banned
Robbinsdale MN
Ok down the frame sounds good but where did you come up into the truck?
through the floor on the passenger side right outside the frame rail. but dont pull it tight and use grommets, the body and frame flex a little from each other. so leave some slack between the floor and the frame. but also make sure you use some sort of sealant around the wires so you dont soak your carpet :p
2drhoeon4s
same here... i have 4 runs down the frame rail and they all come in the cabin under the passenger seat to my battery bank under the center console. works out pretty good.
Handyman
