Wheel Opinions Please
imnohero
South Carolina
My Yukon XL Denali is in order. It's black on black with the Q7M wheels. I am not much of a fan of chrome so I will likely black out the grill and chrome side accents at least. I was going to get aftermarket wheels but think it might be better to paint the stock wheels while blacking out the grill. I don't want too much black so I wanted some opinions on what to do.
Should I black out just the inserts? Paint the wheels a dark gray, etc? Let's here what you all think. I would like a more custom look.
Here is a pic of the wheels on a Yukon for reference.
Rush
NC
Definitely needs an aftermarket wheel... what's more, the 22's are too small for these massive trucks imo--changing the wheels is the easiest and most noticeable way to get a custom look. A 24" wheel w/ 295/40R24s looks at home on these mammoths! Or you can lift it 1.5R/2.5F and go with a 325/45/24. That would be slick too!
imnohero
imnohero
South Carolina
Rush, thanks for the response. Please forgive my ignorance but what's the benefit of going with a 325/45/24 as opposed to a 295/45/24? Is it to fill up more of the wheel well? I was thinking of leveling the truck by bringing the back end down some, not the other way around.
I did order an XL so it's even bigger than the one pictured above.
Rush
NC
In that case a 295/40R24 is the way to go--almost a full inch bigger than a 305/35, which gives you more sidewall, a softer ride and yes, they fill more wheel well.
JackTrills
Fort Mcmurray, AB, CAN
I like the idea of 26in. Rims but unsure of the best Tire size. What would be the max specs for 26in rim to fill as much wheel well.
I want to avoid lowering it by filling in the wheel well
yates ™
Resident Apple hater
Iowa
I think those wheels would look good even if you're set on blacking out the chrome.
imnohero
imnohero
South Carolina
I can say the biggest I would possible go would be 24" wheels. I am just debating whether it's worth it or to just stick with the stock 22's. I will at least paint the interests if I keep the 22's.
Rush
NC
The "best" option for a 26" tire at standard ride height is a 305/30R26 (33.2" circumference)... The 295/40R24 is 33.4, which is why I opted for 24s vs. 26s. You're not going fill well--you need to delete it! i.e Lower it. Or get some 30s lol
imnohero
imnohero
South Carolina
Hey Rush, question, did you level out your truck ? If so, what kind and will it work on the 15 Tahoe ?
Rush did level out his truck. I'm 90% sure he went with NorcalSS's advice. It should be easier on your Tahoe as Rush had to deal with the magnetic ride in his Denali (unless you got a magnetic ride LTZ). NorcalSS gave me a lot of useful info about it. I'm just waiting until I get me truck delivered before deciding whether to level it. You should contact him on here and he'll tell you exactly what you need for the look and ride you want.
TallHoe 96 OBS
