Wheel bearing?
992dr
Eastern N.C.
I have replaced my bearings more than I should be.
What bearings are you using?
Who makes the best bearings for a 2wd Tahoe?
Thanks:Handshake:
Donnie Yukonie
Yates Caretaker
i replace mine alot too although ours are different being 2wd and 4wd i think thats the worst part of these trucks IMO
992dr
992dr
Eastern N.C.
moog/tiken makes the best. and mine are oem at 244k miles.
What he said, hah.
sorry the second name was supposed to say Timken. And why do you guys have to keep changing your hubs all the time?
Not sure why. I only change bearings though, not hubs.
The only thing I can think of is because of my drop. Could it be possible that the alignments bolts have something to do with it? They have not been knocked out even after my drop.
SunlitComet
OBS Jedi-Do Good
unknown at this time.
Well a bad wheel alignment could cuould cause some extra stress for a bearing set on 2wd. Do you get them serviced regularly, spindle surface clean and no damage, good grease and nuts not over torqued?
992dr
992dr
Eastern N.C.
I have read about people knocking out the alignment bolts for new ones when you do a drop.
I'm curious to know how low you need to go to swap alignment bolts. Anyone?
Serviced regularly? I do most if not all the work on my Hoe.
The spindle surface is clean an undamaged. Quality syn grease and tightened then backed off, like specified.
SunlitComet
OBS Jedi-Do Good
you punch for the camber/caster alignment bolts when your vehicle over time can no longer meet the camber/caster specs required in the specs. if you can just adjust toe and others are good just leave them. and it is not bolts you punch but those round discs they go thru because the are tacked to the frame mounts.
Donnie Yukonie
Yates Caretaker
well as for mine i used to wheel it all the time and i know to expect broken parts but ive never had a set last longer than 18 k after my oem blew at 100k but even still
gpracer1
Phoenix
Damn my 93 4x4 got beat up, sunk, duned, etc for 190,000 and never needed bearings.
99 4x4 with 138,000 also oem.
Maybe your bigger tires stress them.
Donnie Yukonie
Yates Caretaker
31s stressing them :yaoface2: well i got 35s coming looks like i better go buy a dozen or two hubs
JPeter
