What makes Dex-Cool so special
indigent
Central Texas
So I'm going to flush my radiator on my 03 Tahoe tomorrow and while I get that Chevy wants Dex-Cool put back in there, I can't help but wonder what makes it so special. Is the green coolant not good enough or can it be used if all the Dex-Cool is flushed out?
4WDTRK
sleeps in garage
Socal dreaming of Norcal
Now they make the green stuff that is compatible with all colors. I haven't done a full flush on my system yet, but I do top up with the dexcool compatible coolant and I'm not too worried.
jerryjoe28
That Guy
cabot AR
There is remarkably little difference between the green antifreeze and DexCool. Both are ethylene glycol-based. Both require a 50/50 mix with distilled water. GM claims tap water is suitable for DexCool, but why introduce unnecessary minerals to your engine? The differences rest in the type of corrosion protection each product offers. Green coolant uses a silicate-based corrosion inhibitor that coats the metal. Over time, these inhibitors break down, requiring a coolant flush every 30k miles or so. In an aluminum engine, green coolant does not change color when it breaks down; so many owners have no idea when this has actually occurred until their nice expensive aluminum heads have cracked. In an iron block engine, green coolant will turn reddish-brown with rust when its corrosion inhibitors break down. DexCool (phased in by GM during the 1995 model year), on the other hand, uses an acidic (GM calls it “organic”) corrosion inhibitor that does not break down over time. However, DexCool does not coat metal components as much as green coolant does, so proper levels must be maintained to ensure corrosion protection. Because corrosion protection does not diminish over time with DexCool, it can be left in the engine much longer than green coolant. While it's disputable whether or not you should leave DexCool in for the 150k miles that GM & Texaco claim, DexCool should easily be able to stay in the engine for 75k miles, two and a half times that of the green coolant. 75k miles is generally what the average vehicle travels in 5 years, and GM does not recommend leaving DexCool in for longer than 5 years.
unoigo
Detroit
Appreciate the info jerryjoe28. Was always curious myself
ccapehartusarmyINF.(ret)
Gilbert AZ
maybe they made so eco friendly that if you ever get stranded in the desert with no water and dying of dehidration you could drink the coolant out of yer radiator and survive
Gilbert AZ
ROLFMAO that actually reminds me of this old b rated movie called suburban commando with hulk hogan and christopher lloyd and the bad guys are trying to freeze hulk hogan with some kinda futuristic freeze gun and after the smoke clears you see hulk chugging this big jug that says antifreeze
and he turns and looks at the bad guys and says" hahaha ANTI FREEZE" and the kicks there ass
SLCHOE
ASE Master Certified + (L1)
Midvale, Utah
I flush DEX out of all of my GM vehicles for one reason. Dexcool doesn't like to be mixed with older non-universal green coolant. What it turns into is ugly. I do all of my own services but if I ran Dex and one day for whatever reason and without my knowing, sombody topped off my coolant reservior with the green stuff, it would totally sludge up all of the coolant passages in my cooling system if I gave it the time to do so. Radiator, heater core, engine passages, hoses, thermostat.... all of it. I flush every winter so that really isn't an issue for me bur for some of you out there, it can be.
So I flush all of my dex vehicles out with water and add in a universal green/red. Dex really isn't that great imo. For the disposable car market and people who lack on maintenance it might be but not me.
Tahoer2008
