What is this part?
r870
View media item 27963View media item 27964I had my check engine light start coming on intermittently, with the codes P018B (fuel pressure sensor issue) and P069E (fuel pump control module) popping up. I noticed that this tube from the air manifold was cracked, and after taping it back together the codes and check engine light went away. I tried figuring out what it was to replace it, but haven't been able to figure out what part it is. It recently came apart again, and the codes and check engine light came back. I fixed it more securely with some heat shrink tubing for the time being, but want to figure out what part it is so I can replace it properly with a new line.
Vehicle is a 2011 yukon xl Denali with the 6.2L engine.
Look like this?:
If so, that's part of your PCV system, the fresh air side. PN# 12609373
Plug your VIN in here and look in Ignition: https://parts-catalog.acdelco.com/catalog/catalog_search.php
Laurents10
