What is the difference?
k1970
Oman
What is the difference between the automatic transmission and the transfer case?
Bill 1960
Testing the Limits
Are you asking why are the service intervals different?
Transmission has more fluid capacity.
Also many more clutches and clutch wear from shifting.
Which lead to the transmission having a filter while the transfer case does not.
All that being said if it’s mine I would use the shortest intervals (or perhaps even less in severe use) and change them both at the same time. Just because it’s one less time in the shop.
Rygrego
Topock, Arizona
Do you seriously not know the difference between a transmission and a transfer case? If you don't know keep going to the dealer for service.
veteran111
