What grease should be used for grease zerks?
JamesLond
I never really thought about it, but I've been using either EP moly grease or multi purpose lithium grease from O'Reilly's Masterpro brand.
The stuff's got a black color to it.
MassHoe04
Western MA
Not to be that wise-guy, but... Depends...
You can use high-temp grease in low-temp locations, but you can't use low-temp grease in a high-temp location.
I always went with a high quality red, high-temp like this one from Valvoline...
or in the tub...
On sale for half-price!!!
$3.29 for 14 oz. grease gun tube
$3.99 for 1 lb. tub.
Gotta get me some...
Just grab a tube of the best stuff at walmart, I like the marine grade lithium myself, a tube will last you a long time
exp500
NGLI EP-2, 3percent moly Black. Do not use on white metals. Steels only. Thats why theres Red EP2.
SnowDrifter
Sasquatch Country
Amsoil polymeric chassis grease, #2
IMO, ball joints should get something with moly in it. Low speed, high load, is a perfect use case for this stuff.
Also IMO, any grease is better than no grease. A dry joint will fail very quickly. I wouldn't get too hung up on it - just grease regularly and sleep easy. I do mine every oil change. ~half pump in each of the fittings. Too much is apt to blow out the dust seals, then you're worse off than you were if you never touched it.
jackal78
