What 3m remover should I use?
Assuming you're talking about the "eraser wheel" you can get it almost any auto parts store. I happened to buy mine from www.latemodelrestoration.com, but you can it several different places. I would just google 3M Adhesive Remover wheel. Very useful tool!!!
Heat gun and rubbing alcohol.
Seems like a harder and much messier process. With the eraser wheel the process is much easier to complete IMO....
White07Tahoe
New Orleans, LA
Hairdryer, goo gone, and then wax gets it done really easy. Make sure you use a soft microfiber towel so you don't leave any swirls.
itsspeeds
Rock Falls, IL
I used a product called "quick and easy". After pulling the emblems off by heating with hair dryer. Sprayed this stuff on let it soak and used a plastic razor blade. After that hit it with a clay bar and done. Haven;t waxed it yet till I get a chance to do the whole truck. Took me little over an hour to do the whole truck.
wardo
never used the wheel thing, i've always let the area soak in the sun, then used hairdryer if needed. run some fishing line behind the badge your removing, then goof off, clay bar, wax. dont forget a cold beer or two. Done
post some before and afters.
You should really try the wheel. Makes the job even easier! :waytogo:
D Rollins
