WATER LEAK`
rj100
1999 Yukon SLE with tailgate and glass lift gate. Where can I get new rubber seals for tailgate lift gate area?
east302
Mississippi
LMC sells it and GM still had it a year or two ago. There are two foam inserts in it that need to align (roughly) with the top of the tail lights. Sometimes they put painted dots on it to make the inserts easier to spot but compare it to the location of your original ones before you remove it.
Timbers
If the weather stripping isn't physically damaged you can usually peel it off, clean it up really well and then use 3M Weatherstripping Adhesive, squirt it into the slot in the weatherstripping that pinches onto the metal frame outline and let it dry overnight. I did this on mine and it stopped the water from coming into the back of the truck.
jackal78
