If it is a "real" suspension lift as in spindles, upper control arms, dif drop, and lower control arm drop brackets, you should be able to add a little more lift seeing the that kit will take everything back to stock angles. I have read that a lot of nnbs truck guys run spacer lifts along with suspension lifts.
I would just not recommend running a spacer lift in addition to the lift similar to the Rough Country 3.5" lift or the Ready Lift SST 4" lift. These two lifts do not lower the control arms so by adding any more lift than the kit does would (IMO) create a lot of stress on the lower ball joint.
I don't understand why people don't do the 2" body lift. IMO, bodylifts are great if they are 3" or smaller. They add the needed tire clearance and are much cheaper than the suspension lifts. I know on the nnbs vehicles, the rear bumper is not supposed to be used for towing after a body lift, but with a little welding, it could be stronger than the stock bumper. This is the route I am leaning towards.
