Robbie The Tiger
- Joined
- Jan 17, 2017
- Posts
- 11
- Reaction score
- 0
First off let me say that I didn't post this in the hybrid section because I don't believe it is hybrid specific.
2012 Tahoe, 160,000 miles, otherwise in great shape. I have a very annoying issue. When it is cold outside (<37 deg F) I will occasionally get a warning bell/ding and the display shows SERVICE BRAKE SYSTEM, SERVICE STABILITRAK, and SERVICE TRACTION CONTROL. There are NO driveability issues when it happens, and it usually clears in a few seconds, only leaving the little skidding car light lit. The displays themselves clear. When I restart the vehicle everything is cleared. Again, this only happens in cold weather, and no other issues are apparent.
I was able to catch it happening one time, when I borrowed a friend's code reader (his was much better than my bluetooth Amazon special with Torque app but still not the GM Tech reader). The code I was able to pull was the U180F which is a data communication loss, data circuit B.
I am not sure how to troubleshoot at this point. I haven't been able to find a network wiring diagram that maybe would show the routing of this data circuit, with wire colors maybe(?) so I could check the wiring at the individual modules and see if there is an intermittent or suspect connection. This all started happening probably about around 120,000 miles. Kind of seems to be getting worse, happened (4) times this morning on the way to work. Soon though, it will be warm enough and I won't have the issue until next fall/winter.
If anyone has a wiring diagram that would help me out in this regard, or can point me in the right direction for one; or if you have had a similar issue or any suggestions at all, it would be appreciated. I would LOVE to fix without dealer involvement (story for another time) but I imagine that is everyone's goal on here
. Thanks
