Two Modifications for Yukon/Tahoe If Your Ride is Rough and no HIDs
Cmicasa the Great XvX
By the way I definitely checked after driving around with them on at night time when I got home after about 30 minutes of driving felt no heat to worry inside of the casing.
I didn't do high beams because I saw it as a waste of money I mean seriously when do I really use them and when I do the stock ones are fine.
The fog lights I did when I bought truck
Finally had a dead bulb (driver side) after almost a year. Contacted MOSTPLUS and they were under warranty. They had this whole process to replace since I bought from Amazon.. but I asked them to allow me to just buy a new set and they'd refund the money once they received the defective ones. They did.. and I am happy
roosh725
Have you had any codes thrown or any problems with running These LED's?
roosh725
To everyone interested, I purchased and installed the same led's in this thread. Significantly better lighting than stock. Nice color, and do not feel hotter to the touch than stock. I'd recommend them especially for the price and 3 year warranty.
Took me 10 minutes to install, plug and play.
Dakota8
Thank you for the post! I think I am going to purchase the high/low beam package you link to from amazon.
K2 Kaiju
The Depths
Just FYI, this post is 2 years old - led bulbs have greatly improved since then. You may wat to look at the newer tech...
Sent from my SM-G975U using Tapatalk
CMoore711
How do these compare to the stock low beams that are led in Denali? I am thinking of only putting in bright led’s Since the stock low beams are led.
Except the stock low beams in the Denali are not LED...
The only lighting LED about the stock Denali headlights is is the DRL strip. Your stock Denali low beams are HID D3S bulbs.
WillCO
Castle Rock, Colorado
I'm not sure, mine is a Tahoe that had the woefully bad halogens as OEM. I actually had someone ask me if my headlights were on or not one time, driving just after twilight. This set was a profound improvement.
Dakota8
I know very little about this but I thought the low beams were LED, the color on the k scale seems to be the same as the DRL strip. So, if I got low beam LED, they would be an improvement over the stock low beams? Also I’m assuming the high beam LED would also be an improvement? I would like to do the fogs, backup, and license plate. They would look nice. I am actually thinking of doing DeAuto or Diode dynamics??
Dakota8
I can’t believe a $70,000+ vehicle that is labeled as top of the line, does not come with led. An extra $200 on the msrp?? Seriously. What a joke.
CMoore711
LED’s for low beam headlights really only work well if the factory headlight housing has projectors specifically designed for LED bulbs. Even at that they don’t have the same throw (distance of light projection) as HID.
LED’s have come a long way but for light intensity, lumens, and throw...
HID > LED.
Dakota8
I have heard HID are better than LED, but I want plug and play that is “led” colored to match and if I can get a better light that is a plus. That being said, do you know if the low/high beam is a projector or reflector? Thank you for the reply
CMoore711
‘15 Yukon XL Denali. OEM stock HID on the right (passenger side) and OSRAM CBI D3S bulb on the left (drivers side).
The OSRAM CBI offers a color closer to 5000K more white without decreasing light output. In fact I think they are brighter.
This is plug and play as all you have to do is swap the OEM D3S low beam bulbs out for these. Again these are HID’s and since your Denali already has factory HID system all you need is a whiter bulb. These also match the factory LED DRL strip very well.
Hope this helps.
WillCO
HID > LED.
I'd read all of that too and initially second guessed my decision to replace with halogens with LEDs. Once I did it, though, the advantage was obvious. And, dropping in LEDs into the existing housing is way easier and cheaper that trying to retrofit HIDs.
Dakota8
Hey thanks a lot. I did not realize the Denali already had HID in low beams.
Hope this helps.
Drewphil
