Trying to eliminate numb steering
GMJedi
Snohomish county
rebuilding my front steering and suspension. Anybody have a good resource for moog components? And where can I get a oem quality reman steering box? I'm keeping the stock height stock wheels and tire size.
2000tahoeZ71
Well I will tell you from experience, if your pitman arm is a ***** to remove off the box, and it takes any forcing at all, the old one will leak. I learned the hard way after I had it put back together it was spewing from the seal like crazy. I was in a pinch and got a reman unit from Oreillys, and it's been just fine. It is important to keep in mind that the set screw thing sets preload. They are supposedly set from the factory but I've heard of them being really loose and super tight from the factory, so you may want to keep than in mind after you get it in.
mfinta
