TRANSMISSION OIL CHANGE
B-train
Depending on the driving style and use it gets makes a difference. If it's mostly highway and low load use, then I do 40 to 50k. If it's more spirited driving, hill or mountain roads, city, trailering etc I would stick to 30k intervals
strutaeng
Dallas, Texas
This is the 6L80/90, right?
I think 50k on that unit is recommended? Maybe as little as 25k if you haven't disabled the AFM/DoD and do heavy towing or a lot of city driving?...see the 6L80e thread from @NickTransmissions for more info.
On the old 4Lxx and earlier models there's this idea that changing your transmission fluid at high mileage will cause it to start slipping because the "old ATF has 'grit' to help the clutches engage." I've heard even reputable mechanics mentioned this like it's the Gospel. I certainly believed this myself. As far as I know that is false, and is an old-wives tale. This should be like a PSA.
There's absolutely no way a friction particle that got abraded away and is floating around in the lubrication circuit can do this. The friction material is bonded to the backing substrate. Keyword: bonded. After it falls off it doesn't do anything. Not to mention all the grit would cause damage to bushings, bearings, valve body valves. Yuk. The proof is converter failure of a 6L80e causing extreme scoring and damage to the pump body. :-(
tom3
I'm doing mine at 30k so I can see what's in the bottom of the pan. I have noticed that when I check the fluid level when I wipe off the stick I get some black stuff on the rag. The actual ATF still looks and smells fine. I really don't like the way that torque converter slips so much. I really wonder why GM went with that?
these people going 100k are the ones you see on the used lot with black transmission fluid.
I wouldn't go over 40k without a change, I do mine about every 25k
I am poor I need these vehicles to make it 10+ years, that means maintaining them, not just driving them until I trade it in for another one to ruin
*and transmissions use transmission fluid, not oil.
dougo
Raleigh
I suck the fluid out with a oil extraction pump the through the dip stick 3.5-4 quarts out and replace it once a year , at the 50K I have it flushed or do the same process 3 times, I tow Mutiple trailers and like Doubelive i am poor and need my truck to last 06 192K In my opinion trans fluid is cheap when found on sale and easy changed with and extraction pump
DonutGodd
I’ve heard too many times from actual transmission guys to do it twice as often as the manual suggests. Last time I did it on my 18’ Yukon I installed a PPE pan and a thermostat reroute too. I can’t stand not having a drain plug. Added a little capacity as well.
tom3
I bought a transmission thermo valve to put on mine when I change it, but I've been watching the trans. temperature and highest I've seen is 192 and that was in a 20 mile traffic jam inching forward. Usual highway and in town is 170s into 180s now and then. Still changing it though since GM actually recommends it.
V8Soulja423
