I am trying to flush the fluid in my transmission. I have a 1998 Tahoe with the 5.7. I followed the instructions on the thread here about flushing the transmission. I have installed the filter and pan. I put the same amount of fluid back that I took out and started the hoe. It would pump about a quart and then start pumping air again. I tried it several times with the same results. The fluid is just touching the dipstick.
Also, I don't know if this matters but now the dipstick appears to be not going all the way in. It stops about an inch short and then I have to push it down and lock it. If I don't lock it, it will push right back out. Any help would be greatly appreciated.
