Transmission Cooler
91RS
GA
I’ve been searching around and it looks like the Trucool 40k is the go to. What I’m having a hard time confirming or denying is if the stock transmission lines will reach it? I thought I saw a post about cutting the one line and extending it but in some pictures it looks like it might reach? I really don’t want to cut up my lines, that’s just another spot for a blow out or a leak.
Is there another option that is more “bolt-in” that the factory lines do reach? Maybe a little smaller? The 40k is probably overkill for mine since the hottest I’ve ever seen it is 180*, which is really ok, but Circle D Transmissions suggests keeping it cooler, so I figured I’d oblige. I’m considering replacing my AC condenser when I replace my AC compressor since the GM one is still available so if I have to take off the front bumper, I’d like to save the time and do it all at once.
St. Louis
I believe you cut the line and flip it so instead of it turning right to go more towards the center of the car it turns left, and use a 3/8" to 3/8" compression fitting
JPeter
