Transfer case fluid?
M3kanic
If you are 4wd you use auto-trac II but if your awd takes dex VI . Unless something has changed since the last time did the research for it.
buck91
Looked it up on the AutoMATE database. Looks like Dex VI is, indeed, the proper fluid for all 2011 Tahoe's.
Bob2C
Northern VA
My 18 manual states Dexron VI for transfer case. Changing OEM fluids out at 23k to AMSoil. Looking to confirm torque specs for my 2018 - Front Diff both plugs 24ft lbs, Transfer case both plugs 13ft lbs, Rear Diff fill 24ft lbs, Rear Diff bolts 29ft lbs. @swathdiver had mentioned these specs in post but they were for an earlier model. Don't know if anything has changed. Thanks
ASG-MikeS
