Trailer hitch
throwback2
Westville,NJ
Looking for recommedations on a trailer hitch for 2001 Yukon 5.3? I will be towing no more than 2500 lbs. Curt,Draw Tite, Thule etc.
Scottydoggs
NJ
what ever falls in your price range, all work fine.
you also need a trailer plug, they sell a round 7 pin that should plug into your existing harness out back. then think about a trailer brake box. with any luck the 01 is pre wired for one.
T
throwback2
Westville,NJ
Thanks. The last 3 vehicles I've had were already set up with hitches.The Yukon is pre-wired though.Probably go with a Curt.
Moderator
People's Republic of Colorado
@throwback2, don't forget to check your local UHaul for price and availability. If they have it in stock you could get away with no shipping. Prices tend to vary widely for essentially the same hitch, I'm sure you've noticed.
T
throwback2
Westville,NJ
Didn't think of that and I have a friend in the business too. I'll talk to him Sunday and see what he says. Thanks
corvette744
2004 Z-71
Northern illinois
I agree with everything but dont think you need a trailer brake box at all thats for electric trailer brakes.The weight he says he will be towing wont have electric brakes on the trailer-hence no need for it.
Scottydoggs
NJ
any trailer rated for 2500 lb likely has brakes, (hes not loading up a little HF trailer with that much weight)
ive done a lot of towing. if you can have working trailer brakes, use em. makes it like nothings back there.
Moderator
Since Cequent owns several brands like Reese and Draw-Tite (and Tekonsha controllers), I would expect any of those three hitch brands to have similar products, probably made in the same factory.
The 7-way round connector (with flat blades) is pretty universal these days, but you can get the tow vehicle side with the 4-way flat next to it for the most flexibility and no extra wiring. Or use an adapter. Depending on the wiring connector by your bumper, eTrailer and other vendors have PNP 7-ways.
+1 with @Scottydoggs on using the trailer brakes if they're on the trailer.
corvette744
2004 Z-71
Northern illinois
Their are no brakes on my trailer and i love it.3000 lbs and up and most around 3000 have surge still no need for the electric trailer brake box-unless your towing over 3000 and your trailer has electric brakes.
may 10th water temp 49 2014 033.JPG 2nd boat was way over 3000 and only had surge no electric brakes only surge no box. IMG_1272.JPG
Scottydoggs
NJ
i had a 4,000 lb boat, tandem axles brakes on both, had no idea the boat was back there stopping. came with drums, i swapped em to disk, had a hydro brake set up.
i tow a 4000 lb landscape trailer daily the brakes burnt out, i miss them so bad, early spring time repairs to come on that thing.
RED TAHOE LS
Rossville, Georgia USA
Seems to me a salvage yard would be more practical for the hitch, that way you will access to any bolts/wiring you may need @ far less $$. I hope I understood your post. JMHO
David g.........:)
01subCT
waterbury ct
Since you guys are talking hitches what did you guys do for roll pans?looks like hidden hitch is outta business is there anything else available that anyone knows of?
bldn10
Memphis
I've shopped Tahoes and Yukons a good bit from time to time and have never seen one w/o the receiver, plug, tow/haul mode. I thought that was standard. (as opposed to the HD Trailering Package)
TallHoe 96 OBS
