Towing with a supercharger
donut slayer
Anybody have any experience towing with a supercharger? I have a 04 Tahoe Z71 5.3 flex. I tow a travel trailer that loaded will be about 7k or less. It pulls good now, but I'm looking for more low end grunt and dont have the $$$$ for a diesel at this time. Will it have cooling issues with the SC? Can the stock 4L60E and 10 bolt handle the added stress?
JennaBear
Resident Ninja
San Diego, CA
We towed/tow with a supercharged vehicle all the time, no issues, so long as you know when to get in it, and when to take it easy.
I had a 2004 Z71 Tahoe, with a Radix/LTs/cam. I did upgrade the transmission cooler to a B&M, but ran the stock Magnusen intercooler. Never an issue, and towed like a champ.
ccapehartusarmyINF.(ret)
Gilbert AZ
you should actually have yer vehicle dynod because yer probably pushing the liimits of your stock 4l60E because i think there good up to about 350 hp and a 5.3 stock is about 320 then throw in a supercharger yer well over 400hp i think you at least need to convert it to a 4l65E
for wieght as long as you dont go much above 7000 lbs you should be fine there is notthing wrong with towing with forced induction diesels are towing machines and they are all turbocharged
JennaBear
Resident Ninja
San Diego, CA
My transmission held up just fine. My only upgrade, was a Vette servo.
Sent from my fone.
01Konvict
Boats n Hoes
Raleigh/SML
Will help towing and great power! Just know when to mash it by rolling into the throttle while in a gear then letting up while shifting to reduce line pressure
JennaBear
Resident Ninja
San Diego, CA
Towing would be the least of my worries. Throwing 12lbs of boost, would cause much more strain on the transmission. The towing rating is not just for the transmission, it is for all other components as well (ie. Brakes, steering, etc)
Sent from my fone.
Gilbert AZ
Sent from my fone.
okay yah lost first it sounded like you were disagreeing with me now it sounds like yer agreeing
---------- Post added at 11:45 PM ---------- Previous post was at 11:34 PM ----------
okay lets clear up one thing horsepower is horsepower to a transmission the tranny dosent care how the horsepower is created
D
donut slayer
Truck is stock except for a BB tune on EFI live. 4x4, 3.73 gears. I do have 35x12.5x17's on it.
JennaBear
Resident Ninja
San Diego, CA
You should be fine, provided your transmission is in good shape to begin with. A TransGo HDII shift kit wouldn't be a bad idea.
Keep in mind, the vehicle will still need the same amount of HP to tow the trailer, with or without boost. So essentially you will be towing in a higher gear, than you would otherwise.
We do drop all major brand superchargers, happy to get you info on any.
Sent from my fone.
Deephaven
I've got a Whipple and will be towing a 7k lb boat around....once I fix my melted transmission. The 6L80 didn't like the extra power.
JennaBear
Resident Ninja
San Diego, CA
How much boost were you running?
Sent from my fone.
---------- Post added at 07:26 PM ---------- Previous post was at 07:02 PM ----------
If you are running Whipple's standard tune, that would make sense. They remove all TM from the transmission, which is not safe with that much power.
Sent from my fone.
rob76
A supercharger is going to wear everything out years before they would otherwise, that's just the cost of it.
Deephaven
Sent from my fone.
Sent from my fone.
It wasn't the supercharger that took out the tranny, it just exposed the flaring really fast. Had full TM on doing my first WOT run and I flared. Trans was shot before I put on the Whipple.
Javie
Burbank Ca.
Is anyone running a supercharger on the older 02-06 tahoe ? If so can i Please get some feedback? Really interested in supercharging my rig . Just wanna here from anyone with this sort of upgrage/experience! Thanks
I installed a Whipple on my 02 Denali a few weeks ago. Install was rough due to their crappy instructions but now it's on it's a blast. Next up is a cam and longtubes. Yee-haw.
ZaZaZazzels
